Corsair Void Pro RGB Battery Replacement
  1. Corsair Void Pro RGB Battery Replacement, Earcup: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Void Pro RGB Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Void Pro RGB Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Void Pro RGB Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
  5. Corsair Void Pro RGB Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Void Pro RGB Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully unplug the wire that connects the battery pack to the headphones.
    • This should not take too much force.
  6. Corsair Void Pro RGB Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the clear plastic covering and set aside.
crwdns2935229:016crwdne2935229:0
Gianna Nobili
crwdns2935283:004/15/19crwdne2935283:0
854 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S9-G13, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S9-G13, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S9G13
crwdns2947412:014crwdne2947412:0
Someone knows where to find the charging connector for the headset or can it be changed for usb-c?
Vincent Poirier - crwdns2934203:0crwdne2934203:0
It can be charge with any other USB mini/micro cable like the one for android phones, prior to USB-C
Unless your model of headset only allows USB-C then yes use any USB-C
Cesar Ruiz -
Can someone please add a link to where you can buy this replacement battery - I would like to order a few.
Cesar Ruiz - crwdns2934203:0crwdne2934203:0
So the battery that I ordered from here is a 700mAh. The on that I ordered from the link here is an 700mAh. Time to send this back and shop again
Justin Bell -
Can u show how to change “Charging Port”??
Jason HKB - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 138
crwdns2942667:0crwdne2942667:0 21,665
