The corsair vengeance i7400 series is compatible with DDR5-5600. When the RAM on this computer stops working the applications slow down or freeze and or operating System Freeze or Crash. Crashing, operating system freezing, and applications slowing down all are very problematic when play a game or working on something important. But it is easy for anyone to change out RAM correctly with some simple tools. Before you start to replace the RAM, you must have a Phillips-head screwdriver and two 16 or 32 Gigabyte RAM memory card that total to 32 or 64 Gigabytes.
NOTE: use an anti-static wrist strap when working to prevent circuitry damage.
remove the front panel to get to where the RAM is.
Insert the new RAM completely to where they all click into place and are secure.
Lastly put the front panel back on and turn on the Pc like normal.
When you are done make sure everything is put in correctly. If the Pc doesn't turn or you might have not turned on correctly by not hitting the switch or put the RAM in incorrectly. If you have done everything correctly the computer will come on and you can continue with what you were doing.
crwdns2935229:05crwdne2935229:0
