Corsair Scimitar Mouse Wheel Replacement
  1. Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heat the mouse feet with a heat gun to loosen the adhesive.
    • Pry the mouse feet off of the mouse with the metal spudger.
  2. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 8.9 mm bottom screws with a JIS #00 screwdriver.
    • Loosen the keyslider lock with a 2.5 mm hex screw driver.
  3. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry along the seam of the mouse body to separate the top and bottom halves.
  4. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the top cover from the mouse.
  5. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the locking mechanism on the auxiliary switch board ribbon cable connector with a plastic spudger.
    • Pull the ribbon cable gently to disconnect from the main board.
  6. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the locking mechanism on the Key Slider assembly ribbon cable connector with a plastic spudger.
    • Pull the Key Slider assembly ribbon cable gently to disconnect it from the main board.
  7. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the Keyslider ribbon cable up and out of the plastic post.
  8. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a JIS #0 screwdriver to remove the 6 mm screw from the key slider assembly.
    • Remove the key slider assembly from the body of the mouse.
  9. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the data cable from the auxiliary switch board.
  10. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a JIS #0 screwdriver to remove the two 6 mm screws from the auxiliary switch board.
    • Remove the auxiliary switch board.
  11. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a JIS #0 screwdriver to remove the three 6 mm screws from the main board to separate it from the mouse body.
  12. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the data cable from the main board.
  13. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the main board off of the body of the mouse.
  14. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the scroll wheel gently away from the rotary encoder switch to remove it.
    • Check the rotary encoder hex hole to make sure it is clear of debris.
  15. Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Corsair Scimitar Mouse Wheel Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber ring from the scroll wheel.
crwdns2935229:05crwdne2935229:0
Amelia Camp
crwdns2935283:010/06/22crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-7, Raign Fall 2022 crwdns2935289:0University of North Texas, Team 2-7, Raign Fall 2022crwdne2935289:0
UNT-RAIGN-F22S2G7
crwdns2936753:07crwdne2936753:0 65
crwdns2936753:030crwdne2936753:0 247
crwdns2942667:0crwdne2942667:0 8,145
