Did you spill coffee or any other liquid on your Corsair K65? Or do you just need to open up the keyboard to access the interior? This guide will teach you how to do either one of those!
Unplug your keyboard. The wire is located near the back and on the bottom of the keyboard.
Place your keyboard onto a workspace with plenty of room.
Pry each keycap off by grabbing the keycap with your fingers and pulling directly up.
Unscrew the exposed 9mm Phillips #0 screws with your mini Phillips #0 screwdriver.
Peel back the Corsair logo with a knife.
Remove the logo, exposing another 9mm Phillips #0 screw.
Unscrew the now exposed 9mm Phillips #0 screw.
Carefully separate the bottom half of the keyboard from the top half of the keyboard.
Apply the rubbing alcohol to your cotton pad.
Wipe down the affected parts of the keyboard interior with the alcohol-soaked pad.
Allow the interior of the keyboard to dry for a few minutes before reassembling the keyboard.
crwdns2935229:025crwdne2935229:0
crwdns2947412:05crwdne2947412:0
キーボードの中に液体が入ってしまい、どうしようかと困っていたところこちらのサイトに辿り着きました。
丁寧な説明のお陰で無事、拭き取ることが出来ました。本当に有難うございました。
useless guide. buttons cant be cleaned
Robert Lipowski (robdevilXI) - crwdns2934203:0crwdne2934203:0
broke the white and blue connector, no way to get the board in the same orientation as you did.
Extremely bad guide. Doesn’t go over how the switch to change the LEDs need to be carefully moved away or it will snap. I can’t imagine how many people you’ve costed a keyboard. 0/5 stars.
Nice guide, helped me to clean the board after I spilled a drink on my beloved board. ade some comments at points that proved difficult for me. Unfortunately I only understood what the white plastic thingie that fell out is used for after I reassembled the keyboard. It is supposed to sit on the LEDs to dim them and even out the light.
