Remove the vacuum hose adapter at the back of the device.
With the help of a screwdriver, unscrew and open the device.
Use the lever to unlock the cover.
Using pliers, remove the clip beside the blade holder.
Take off the blade holder, then raise the slide located at the end of the holder.
First, put the slide onto the new blade bracket.
Put the blade bracket back in its place.
Replace the clip in the same place. The curved side of the clip needs to go into the round side of the bracket.
Close and screw the device back together.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2917034:0crwdne2917034:0
Bonjour,
Je suis intéressé pour changer ce support de lame, le mien étant défectueux … les lames ne tiennent plus. Ou est-ce que je peux trouver cette pièce ? Merci Bruno
