Coolpix S01 Zoom Trigger Replacement
  1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Zoom Trigger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Coolpix S01 Zoom Trigger Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Coolpix S01 Zoom Trigger Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Zoom Trigger Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Coolpix S01 Zoom Trigger Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. With the Hex and the J000 bit remove the two 1mm screws.
  4. Coolpix S01 Zoom Trigger Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Coolpix S01 Zoom Trigger Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the needle nose tweezers to remove the black ring in the middle of the button.
    • You have successfully removed the zoom trigger and can replace with a new one if needed.
    • To reassemble follow steps in reverse.
angelica fitzgerald
crwdns2935283:010/13/15crwdne2935283:0
216 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 2-3, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 2-3, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S2G3
crwdns2942667:0crwdne2942667:0 472
