Coolpix S01 The power button won't turn on Replacement
  1. Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First make sure the camera is powered off.
    • Then take the Hex and PH000 bit to remove a 2mm screw on the left side of the camera.
    • Next, remove the 2mm screw on the right side of the camera.
  2. Coolpix S01 The power button won't turn on Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Coolpix S01 The power button won't turn on Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Coolpix S01 The power button won't turn on Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 3mm screw from the bottom of the camera.
    • Once the 2mm and 3mm screws are removed, use the plastic opening tool to lift the sides of the camera and reveal the inside of the camera.
    • Be sure to remove the battery before continuing to repair.
  3. Coolpix S01 The power button won't turn on Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Coolpix S01 The power button won't turn on Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Coolpix S01 The power button won't turn on Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. Using the hex and the J000 bit remove the two 1mm screws.
    • Take the needle nose tweezers to remove the power button.
  4. Coolpix S01 The power button won't turn on Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You have successfully removed the power button and can replace it if needed.
Rieana Hayes
crwdns2935283:010/13/15crwdne2935283:0
Sam Houston State, Team 2-3, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 2-3, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S2G3
crwdns2942667:0crwdne2942667:0 872
