Coolpad Rogue Battery Replacement
  1. Coolpad Rogue Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding onto the phone with your other hand, insert a clean fingernail into the USB port and pull up on it until the cover pops out of place.
    • You may wish to use a thick screwdriver to pop out the cover instead. Be careful as to not damage the USB port if you choose to do this.
  2. Coolpad Rogue Battery Replacement, Removing the cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Coolpad Rogue Battery Replacement, Removing the cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Coolpad Rogue Battery Replacement, Removing the cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While still holding onto the phone with your other hand, pull up on the loosened cover until it pops out.
    • The cover is durable and can be opened several times, so don't be afraid to use extra strength to pop open the cover.
  3. Coolpad Rogue Battery Replacement, Battery Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Coolpad Rogue Battery Replacement, Battery Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Coolpad Rogue Battery Replacement, Battery Removal: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a fingernail in the notch at the bottom of the battery. Lift the bottom of the battery up, then remove it.
    • Take good care when handling a battery and keep sharp tools away from it. Puncturing the battery can cause injury.
  4. Coolpad Rogue Battery Replacement, Finished: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is now removed from the phone.
    • When reinstalling a battery, make sure the battery is inserted with the right side up. The battery design should prevent you from inserting it the wrong way
To reassemble your device, follow these instructions in reverse order. Make sure to press firmly around the back cover when reinstalling it to ensure it is securely in place
Hunter
crwdns2935283:003/22/21crwdne2935283:0
170 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 647
