Contour Roam2 Rotating Lens Replacement
crwdns2869540:0crwdne2869540:0: 1,5K
2
24
92
1.529
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
This guide will give you step-by-step instructions on how to replace the rotating lens cover on your Contour Roam2. Follow this guide if the lens been scratched or damaged.
    1. Contour Roam2 Rotating Lens Replacement, Rotating Lens: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
    2. Contour Roam2 Rotating Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Contour Roam2 Rotating Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate the metal ring counterclockwise until completely removed.
    3. Contour Roam2 Rotating Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to pry up the black rubber ring around the lens cover.
      • The black rubber ring is vey thin and can easily tear. Use caution when removing.
    4. Contour Roam2 Rotating Lens Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove and replace the lens cover.
Matthew Kofsky
crwdns2935283:003/11/15crwdne2935283:0
548 crwdns2915208:0crwdne2915208:0
Colorado Springs, Team 4-5, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 4-5, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S4G5
crwdns2936753:030crwdne2936753:0 92
crwdns2959996:0crwdne2959996:0 1,529
