If your headphones aren't working with your Contixo V8 (model number V8X), be sure to troubleshoot the issue before deciding to replace the headphone jack; if you've determined the jack to be the issue, you can follow this guide for information on how to replace it.
You will need two iFixit plastic opening tools, a Phillips size #000 screwdriver, and a soldering iron or gun with a small tip. Please see this guide for information on soldering and desoldering connections within your device. A plastic spudger would also be useful, but is optional; the iFixit opening tools would work in its place. You may also want to consider using an anti-static wrist strap and anti-static mat to protect yourself from accidental electric charges while working on your device; see this guide for information on how to use these items.
Find the edge of the tablet, where the front panel meets the sides. Use the plastic opening tools to pry the panels apart.
Lift the face of the tablet.
Remove the three 1.4 mm screws from the motherboard with the Phillips size #000 screwdriver.
The cable marked in red is locked into place by two dark pull tabs; pull each away from the cream connection port towards the edge of the tablet. Gently remove the cable once the tabs are in the open position.
The cables marked in orange are known as zero-insert force cables. To remove the connection, flip up the dark tab and gently pull the ribbon away.
Lift the motherboard off the base and flip it over to access the headphone jack. Make sure you have the right port; check that it's shaped for headphones to be plugged in, and not the charger.
There will be a total of five connections between the headphone jack and the back of the motherboard; desolder all five. See this guide for information on how to desolder connections.
Remove the desoldered jack. It is now ready to be replaced.
