Connect Four Electronic Handheld Buttons Replacement
crwdns2869540:0crwdne2869540:0: 884
20
101
884
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
If the buttons on your Connect Four have been damaged, you will need to replace them. If the buttons are torn, you will need to purchase a new button sheet. If the buttons are unaligned, simply readjust the button sheet. In order to get to the buttons, you will have to remove the casing on the back of the device. This requires a Phillips head screwdriver.
    1. Connect Four Electronic Handheld Buttons Replacement, Ensure the device is off.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
    2. Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Connect Four Electronic Handheld Buttons Replacement, Removing the battery casing.: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
      • Slide the cover off and remove the battery.
    1. Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Connect Four Electronic Handheld Buttons Replacement, Removing/Replacing the Back Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
      • Carefully remove the back casing.
      • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
    1. Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Connect Four Electronic Handheld Buttons Replacement, Detaching the Circuit Board: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a Phillips head screwdriver, remove the six (0.25"-length) #3 screws that hold down the cpu board.
      • Using a spudger, lever the circuit board just enough to where you can easily access the button sheet.
    2. Connect Four Electronic Handheld Buttons Replacement, Removing/ Replacing the Button Sheet: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Take out the button sheet, and replace it with a new one.
Julia Wyder
crwdns2935283:010/22/14crwdne2935283:0
110 crwdns2915208:0crwdne2915208:0
Baylor, Team 8-11, Williams Fall 2014 crwdns2935289:0Baylor, Team 8-11, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S8G11
crwdns2936753:030crwdne2936753:0 101
crwdns2959996:0crwdne2959996:0 884
