Compaq Presario CQ62-215dx Fan Replacement
  1. Compaq Presario CQ62-215dx Fan Replacement, Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop upside down, and unscrew all the 3.0mm screws on the back cover with a Phillips screwdriver.
  2. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the Battery and the placeholder for the RAM and the Hard Drive
  3. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are four 1.2mm screws under the battery that are needed to be removed with a Phillips screwdriver.
  4. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop back, and open the laptop cover. Use a spudger or your hand to carefully remove the keyboard.
  5. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the keyboard is out, use the Metal Spudger or your hand in the corner of the laptop to lift the outside frame.
  6. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will have a bigger view of the entire motherboard and there should be screws that are still connected on it.
    • Unscrew all the 1.2mm screws on the motherboard and in the top corner that secures the fan with a Phillips screwdriver.
  7. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the wires connected to the mother board with the Metal Spudger
  8. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 3mm screws beside the fan with a Phillips screwdriver.
  9. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If all the screws have been removed, you should be able to lift the motherboard out carefully.
  10. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When the motherboard is removed, flip it over, and you will have a view just like in the picture.
  11. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips screwdriver to unscrew the three 2mm screws that connect the fan to the CPU.
  12. Compaq Presario CQ62-215dx Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the current fan from the motherboard and replace with new component.
    • When reassembling, you will need to reapply thermal paste on the CPU.
Breana Thibodeaux
crwdns2935283:003/24/19crwdne2935283:0
760 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G1, Valliere Spring 2019 crwdns2935289:0UMass Dartmouth, Team S4-G1, Valliere Spring 2019crwdne2935289:0
UMASSD-VALLIERE-S19S4G1
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 671
