Compaq Presario CQ60-211DX Display Assembly Replacement
  1. Compaq Presario CQ60-211DX Display Assembly Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start by making sure the CQ60 is powered down and that the disk drive is empty.
    • Flip the device over and remove the battery.
  2. Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber screw covers next to each of the two screen hinges using a metal spudger.
    • Unscrew the screws underneath the rubber cover using the blank Phillips-head screwdriver.
  3. Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to gently pry the plastic faceplate off the rest of the display.
  4. Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws in the top corners to separate the frame holding the assembly from the plastic of the lid.
  5. Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the assembly from the chip located between the hinges by pulling the wires to the right.
    Bonjour.
    Je voudrais demander comment on appelle les câbles (2) qui connectent l'ordinateur au moniteur. Est il possible de les avoir?? Et si jamais l'un d'eux se casse pendant la monté d'un nouveau moniteur, que faire ?
    JB449 - crwdns2934203:0crwdne2934203:0
    Bonjour,
    Si j'ai bien compris, vous parlez des 2 fils rouges et blancs sur cette image (à l'étape 5).
    Le connecteur avec les 2 petits fils susmentionnés, c'est le connecteur d'alimentation du rétro-éclairage CCFL de l'écran (ancien type de rétro-éclairage). Ce connecteur est branché sur la carte électronique régulatrice de tentions (en vert sur l'image). Cette carte électronique permet d'alimenter le rétro-éclairage de l'écran.
    Le connecteur d'alimentation CCFL est soudé à l'écran, il est fourni avec l'écran lorsqu'on recherche un écran pour ce modèle.
    L'écran est allimenté séparément de son rétro-éclairage (c'est pas le même câble)
    J'ai trouvé l'écran où on voit le câble d'alimentation du rétro-éclairage qui y est relié.
    En cherchant :
    "Compaq CQ60-211DX screen",
    Pour la carte régulatrice de tentions je l'ai trouvée en cherchant :
    "Compaq CQ60-211DX LCD inverter board"
    Note : sur le net la carte régulatrice de tension est parfois fournie avec la nappe d'écran LCD (nappe de donnée et d'alimentation de l'écran).
    Brendan -
  6. Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the frame forward, and then unscrew the three screws on each side.
  7. Compaq Presario CQ60-211DX Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the ribbon cable on the back of the display by peeling back the tape and then pulling down on the cable.
Garrett Carter
crwdns2935283:009/21/18crwdne2935283:0
492 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S2-G3, Riccardelli Fall 2018 crwdns2935289:0University of North Texas, Team S2-G3, Riccardelli Fall 2018crwdne2935289:0
UNT-RICCARDELLI-F18S2G3
My laptop model Compaq predario cq61 h
Rashid 007 - crwdns2934203:0crwdne2934203:0
Computer on but display light of computer is running
crwdns2942667:0crwdne2942667:0 1,296
