Compaq Presario CQ60 Top Case Replacement
  1. Compaq Presario CQ60 Top Case Replacement, Slide battery latch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Slide battery latch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide battery latch to left
    • Simultaneously lift battery
  2. Compaq Presario CQ60 Top Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove battery
  3. Compaq Presario CQ60 Top Case Replacement, Remove hard drive cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen 2 phillips screws
    • Lift and remove cover
  4. Compaq Presario CQ60 Top Case Replacement, Remove drive caddy: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Remove drive caddy: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Remove drive caddy: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 3 M2.5x4mm screws
    • Slide caddy forwards
    • Lift tab to remove caddy
  5. Compaq Presario CQ60 Top Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 4 phillips screws to remove drive from caddy
  6. Compaq Presario CQ60 Top Case Replacement, Unscrew keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Unscrew keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 3x M2.5x4mm
  7. Compaq Presario CQ60 Top Case Replacement, Lift keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Lift keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Lift keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the keyboard in the middle with a spudger
    • Remove 4 clips by bending keyboard in middle, do not force the clips at the sides
    • Do not remove the keyboard fully, it is attached via a ribbon cable
  8. Compaq Presario CQ60 Top Case Replacement, Detach ribbon cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Detach ribbon cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Detach ribbon cable: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift keyboard slightly
    • Push each side of ribbon cable connector
    • Fully remove keyboard
  9. Compaq Presario CQ60 Top Case Replacement, Remove screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Remove screws: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Remove screws: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 2x Phillips M2.5x8mm screws from under the display
    • Remove 4x Phillips M2x2.8mm screws from the battery compartment
  10. Compaq Presario CQ60 Top Case Replacement, Disconnect ribbon cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Disconnect ribbon cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Disconnect ribbon cable: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn over the laptop
    • Use a spudger to lift the ribbon cable hinged clip
    • Pull the ribbon cable out of the connector
  11. Compaq Presario CQ60 Top Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lifting the bezel by the screen
    • Slide the bezel back towards the screen to release it from the clips
  12. Compaq Presario CQ60 Top Case Replacement, Remove bezel: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Fully remove bezel
  13. Compaq Presario CQ60 Top Case Replacement, Remove screws: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Remove screws: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4x #1 Phillips M2.5x8mm screws from the bottom case
    • Remove 2x #0 Phillips M2x4mm screws from hard drive bay
  14. Compaq Presario CQ60 Top Case Replacement, Disconnect mouse ribbon cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement, Disconnect mouse ribbon cable: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger lift the mouse ribbon cabe latch
    • Do not remove yet
  15. Compaq Presario CQ60 Top Case Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 4x #1 Phillips M2x5mm
    • Remove 1x #0 Phillips M2x2.6
  16. Compaq Presario CQ60 Top Case Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting at the edge by the screen, use a spudger to unclip the top case
    • Work around both sides and finish with the touchpad
  17. Compaq Presario CQ60 Top Case Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Compaq Presario CQ60 Top Case Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift top base off of laptop, being careful to disconnect the touchpad ribbon cable
Mike B
crwdns2935283:011/07/13crwdne2935283:0
1 045 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 536
