The Video Interface Controller (VIC) is is the graphics chip for the C64.
1. Remove three 6.75mm ph2 screw heads from the casing
2. Split the case of the C64 open by pulling up on the case towards you
1. Detach the multi-colored wire bundles that's connected to the motherboard
2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
