Commodore 64 VIC Chip Replacement
  1. Commodore 64 VIC Chip Replacement, Removing screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Commodore 64 VIC Chip Replacement, Removing screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Commodore 64 VIC Chip Replacement, Removing screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 VIC Chip Replacement, Opening: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Commodore 64 VIC Chip Replacement, Opening: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
    Good advice, but is there a reliable way of keeping the clips intact?
    coryengel - crwdns2934203:0crwdne2934203:0
    And probably never will fill it out.
    Motlow48 - crwdns2934203:0crwdne2934203:0
  3. Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Commodore 64 VIC Chip Replacement, Detach the keyboard from the motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
  4. Commodore 64 VIC Chip Replacement, Pull up the VIC plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Commodore 64 VIC Chip Replacement, Pull up the VIC plate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 2. Without using any tools prop up the metal VIC plate with both hands to expose the VIC chip.
  5. Commodore 64 VIC Chip Replacement, Removing the Chip: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Commodore 64 VIC Chip Replacement, Removing the Chip: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 3. Use a Phillips screwdriver to pry up the VIC chip. Then, use your hands and with small pressure pull it away to remove it from the motherboard.
    • You can insert a new VIC chip by making it clip back in on the board
    Carful with that removal, you can easily bend legs or put too much stress on the chip itself. Also much preferred to use a *flat* screwdriver and make sure to not bruise any traces on the motherboard. The proper way to do it is to also remove the metal frame around that area, then use a chip removal tool if available - or at least be able to lift the chip carefully from both sides evenly.
    Bård Larsen - crwdns2934203:0crwdne2934203:0
    I concur; the photo in question offers limited guidance. Upon closer examination of the second image, where the chip has been removed, it becomes evident that there are visible traces on the board. Furthermore, the angle at which the screwdriver is positioned suggests that force may have been applied directly to the board, creating an impression of potential leverage.
    nirv - crwdns2934203:0crwdne2934203:0
Silvanus Clarke
crwdns2935283:009/26/14crwdne2935283:0
677 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 13-6, Staggers Fall 2014 crwdns2935289:0USF Tampa, Team 13-6, Staggers Fall 2014crwdne2935289:0
USFT-STAGGERS-F14S13G6
It's awesome to see that people care enough about these machines to make repair guides about them! Great job!
[deleted] - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,899
