Commodore 64 3AG fuse Replacement
  1. Commodore 64 3AG fuse Replacement, Removing screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Commodore 64 3AG fuse Replacement, Removing screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Commodore 64 3AG fuse Replacement, Removing screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1. Remove three 6.75mm ph2 screw heads from the casing
  2. Commodore 64 3AG fuse Replacement, Opening: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Commodore 64 3AG fuse Replacement, Opening: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 2. Split the case of the C64 open by pulling up on the case towards you
    • Do not pull too hard that you break the clips.
    Good advice, but is there a reliable way of keeping the clips intact?
    coryengel - crwdns2934203:0crwdne2934203:0
    And probably never will fill it out.
    Motlow48 - crwdns2934203:0crwdne2934203:0
  3. Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Commodore 64 3AG fuse Replacement, Detach Keyboard from motherboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 1. Detach the multi-colored wire bundles that's connected to the motherboard
    • In this picture, the power indication LED (connected to the black and red wires) is not fastened to the keyboard panel, yours might be different.
  4. Commodore 64 3AG fuse Replacement, Locate 3AG fuse: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2. Find the 3AG fuse located next to the joystick ports and On/Off switch
  5. Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Commodore 64 3AG fuse Replacement, Removing the 3AG fuse: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 3. Using the ifixit splugger, prop out the 3AG fuse from the clip.
    • * Replace the 3AG fuse by inserting the new fuse and letting it pop into the clip
Silvanus Clarke
crwdns2935283:009/26/14crwdne2935283:0
677 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 13-6, Staggers Fall 2014 crwdns2935289:0USF Tampa, Team 13-6, Staggers Fall 2014crwdne2935289:0
USFT-STAGGERS-F14S13G6
The fuse is 1.5 Amp, not 3
JC Andy - crwdns2934203:0crwdne2934203:0
3AG does NOT mean a fast acting fuse. It could be either fast or slow blow. The 3 means it's 1 1/4 " long, the "A" means it has Axial connections, and the "G" means it's made of glass.
Toon Konings - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 4,103
