Si vous souhaitez tester votre Samsung Galaxy, vous pouvez le faire via le Menu Test.
Il y a deux menus de test.
crwdns2936621:0crwdne2936621:0
Pour entrer dans le menu, tapez ce code :
*#7353#
Maintenant vous pouvez tester les capteurs de luminosité et de proximité, l'accéléromètre, l'écran tactile, la caméra principale, etc.
Entrez ce code :
*#0*#
Ce menu est identique au précédent.
Bonjour qu1nd je tape le code *#0*# ça me dis “place open book cover” je ne comprends pas je suis sur un galaxy a3 2017
Punya saya gak kenak kalau pakai kode *#0# knpa ya kalau selain kode itu bisa semua
This will only work with the Samsung Android on the phone, not with an alternative OS.
crwdns2935229:064crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:016crwdne2947412:0
I have a5 2016 sm5100 .....and codes are not work why????
Doesn't work. These "tutorials" are always bullshit.
They worked for me
code for engineer mode
Hello! I got weird error for *#0*#. I entered it and i got message like: " Plase Open Book Cover." Not "Please..." either. Can you help me? I would really appreciate your help and work. Thank you.
You upgrade to Android 7 and the *#0*# goes bye bye. Don't know why, but it does.
I am having the same issue “plase open book cover “ And my phone is already updated to Android 7. Further my sim jacket broke down and I opened the phone and later the hands free didn't work as well as *#0*# shows the plase open book cover. What should I do now?
if u r having mobile cover on the mobile , just remove it and try code *#0*#
It works !!! Thanks !!!
Just remove de cover on the back !!!
I was concerned about the accuracy of the touchscreen on my Samsung Galaxy A5 2017 with Android 7.0 . I did both of these tests and both confirmed that the screen was very accurate indeed. Many other tests are also available to test just about every sensor, input and output on the phone. I am very pleased with these findings. Many thanks to the people who brought this to light!
Hello Gents
Would anyone please post act. part number for Magnetic Sensor Samsung A5 SM-520F
Many Thanks
hello,
the code *#0+# works only until android 6.xx on samsung galaxy s6 edge !! On Android 7.0 is not working anymore ! you got a message " please open book cover " but that is a wrong message because the code is not working on Android 7.0 !! Another code is *#7353# test menu hardware !
regards,
the first code did work thanks
Worked for me although I didn’t understand exactly what some of them were checking, but hey-ho I’m not a phone engineer.
Thank You, was problem with cover. it was a film on the Display. I just needed to remove it.
1. Samsung Secret Codes for Phone Info and Test Functions
*#06#, this code will display the IMEI number.
##4636#*#*, this code will show you diagnostic and general settings mode.
##7780#*#*, it will make Factory Soft reset or you can also use *#7780# for the same.
*#1234# will display the current firmware.
27673855# for Factory Hard Reset to ROM firmware default settings.
27674387264636# to display the product code.
#272imei#* to display or change CSC Code or you can also use #272HHMM#*.
##1472365#*#* for GPS test settings.
##197328640#*#* to enter Service Mode Main Menu.
