Appuyez brièvement sur le bouton d’augmentation du volume (1)
Appuyez ensuite brièvement sur le bouton de diminution du volume (2)
Pour finir, maintenez le bouton latéral enfoncé jusqu’à ce que le logo Apple apparaisse (3)
please what do i do when my iphone X shows Up the Itunes Sign and needs to be Reset ….. And please how do i reset it
I’ve been trying to restart my iPhone X since yesterday night… doing it the way I always do (volume up or down and hold side button) and NOTHING. I just came to look for help online and all the same thing. BUT I found your way… and I got my phone back!!!! It was frozen on the same screens, unresponsive. THANK YOU!!!
It didn’t work :(. I’m pressing the button….
how to know what happen with my iPhone X. dark only could not charge. I did not used a week.
Nope... still frozen cycle....
Yay!! Finally found a simple and easy fix!! and it worked
Still pressing didn't show on
Merci beaucoup
Merci beaucoup. mais je une question par exemple si je veux regarder une vidéo je n'arrive pas pourquoi?
My iPhone 10x r - not switching on , only ap
Ple logo is appears for 2 seconds then it disappears , again the same being repeated , but iPhone is not becoming ON
S Bardava Jaipur India
crwdns2935229:0133crwdne2935229:0
crwdns2947412:014crwdne2947412:0
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
good share. thanks.
What is the other way?
will it delete all data from my iPhone?
No, it will only reboot the operating system. Your data and settings will persist.
Génial. Ca a bien fonctionné même sur un Iphone 12
Didn’t work. Now what?
It's not working for me, please anymore ideas?
Apple logo didn't show on screen,just empty battery sign
hi this literally saved my life thank you so so much!
Face ID has stopped after changing the screen, how to fix
You have to have a machine that puts the old serial number on the new part so the phone recognizes it. It's called "parts pairing" and it's why Apple sucks. I have seen someone do it with an EEPROM reader/writer but I could not find one for purchase so you would need to go to an Apple-authorized repair tech to have your new parts reserialized.
enormous thanks even if i was sceptic, incredible life hack huuuuuuuge thanks
