Realizar un reinicio forzado no debe eliminar ningún dato, pero puede ser útil si su iPhone X está congelado o necesita solucionar algún problema.
Presione brevemente el botón para aumentar el volumen (1)
Luego presione brevemente el botón para bajar el volumen (2)
Finalmente, mantenga presionado el botón lateral (3) hasta que aparezca el logotipo de Apple y luego suéltelo.
Has terminado
Has terminado
crwdns2935229:0126crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2944067:013crwdne2944067:0
You saved my day. My iphoneX did not respond to anything after connect with the itune. I tried to shut down by holding volume up/down + side button but it didn’t work. So I tried your method and it worked!!! Thank you so much
This is a temporary solution whenever my iphone gets unresponsive i used this method but after some time it again starts doing same laggy and unresponsive behaviour
good share. thanks.
What is the other way?
will it delete all data from my iPhone?
