Comfort Zone CZ6C Switch Replacement
  1. Comfort Zone CZ6C Switch Replacement, Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement, Switch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement, Switch: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
    • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
    • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
  2. Comfort Zone CZ6C Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic cover on the switch by pulling it apart from the the back panel.
  3. Comfort Zone CZ6C Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
    • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
    • Disconnect the gray power wire from the switch by desoldering the connection.
  4. Comfort Zone CZ6C Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cut the green and yellow wire as close to the switch connection as possible.
  5. Comfort Zone CZ6C Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Strip the green and yellow wire about two centimeters from where it was just cut.
  6. Comfort Zone CZ6C Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the switch from the back panel and remove it.
  7. Comfort Zone CZ6C Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Comfort Zone CZ6C Switch Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
James Abundis
crwdns2935283:004/08/15crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-5, Forte Spring 2015 crwdns2935289:0Cal Poly, Team 17-5, Forte Spring 2015crwdne2935289:0
CPSU-FORTE-S15S17G5
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,417
