Learn how to properly replace the power cable of your Comfort Zone CZ6C.
            Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
            Unscrew the yellow cap that connects the black wire and the gray power cord wire. Then, unwind the tied wires and pull them apart.
            Remove the plastic cover on the switch by pulling it apart from the back panel.
            Disconnect the gray power wire from the switch by desoldering the connection.
            Strip the end of the gray power cord.
            Then solder the end of the gray power cord to the switch.
