Replacing your fan blade is simple and requires tools found around your household.
            In order to remove the metal cage, place one hand firmly on the back plastic body and your other hand on the metal cage.
            Now work your way around the edge of the fan cage and pull it away from the plastic body.
            To remove the fan blade, reach behind it and slowly pull it towards you.
Where does one buy the replacement blades?
where does one buy the replacement blades??
