How to Upgrade the Fiat 500 Uconnect 5" Firmware
    • Download Version Firmware (VP2 CO version)
    • Extract the zip file and copy it to the USB stick. A USB2 stick is advised with a capacity of at least 2GB and no more than 16GB.
    • If you get a not compatible error during this process upgrade to 12.00.24.01 followed by 13.00.57.05 before finally upgrading to 13.00.74.00. this will ensure you have a upgrade path.
    • If you are on a 13 .xx.xx.xx version already, above should not be required. Any verion older than 12.xx.xx.x uplifting to 12.00.24.1 should get you there
    • You can can download the firmware from the fiat forum.Click here to download firmware
  1. How to Upgrade the Fiat 500 Uconnect 5" Firmware: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert USB stick into Fiat 500 USB port
    • Turn on engine (keep it running to avoid battery drain)
  2. How to Upgrade the Fiat 500 Uconnect 5" Firmware, Start Upgrade: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Raido on pressing the power button
    • Press contiune. To the safe driving message.
    • Mute the raido to avoid audo noise during upgrades.
    • Press Start
  3. How to Upgrade the Fiat 500 Uconnect 5" Firmware: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 How to Upgrade the Fiat 500 Uconnect 5" Firmware: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The Firmware will start to upgrade
    • If your FIAT 500 is an automatic you will hear the robotic arm charge. This is normal. The Raido may also go blank or the bar may dissapear.
  4. How to Upgrade the Fiat 500 Uconnect 5" Firmware: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • One complete the unit will restart.
    • Remove the USB Stick
Your firmware is up-to-date. Repeat if needed until you have uplifted to the latest version.
Tom
crwdns2935283:005/04/14crwdne2935283:0
1.708 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Hallo ich brauche eure Hilfe. Neuen Radio MIT Navi zugekauft für 500L - der Original Radio war OHNE Navi! Leider hängt sich das Navi beim Starten immer nach kurzer Zeit auf!! Kann der neue Nav-Radio dem Steuergerät „angelernt“ werden? Danke für jede Hilfe! In zwei Fiat Werkstätten war ich schon, leider ohne Erfolg.
mamy - crwdns2934203:0crwdne2934203:0
Angeblich kann in einen Fiat (in meinem Fall 500L 2013) serienmäßig OHNE Radio mit NAV ausgerüstet, KEIN Radio MIT NAV eingebaut werden!? Kann da jemand helfen? Vielen Dank Manfredo
Is that compliant to the 7” version?
senseiken - crwdns2934203:0crwdne2934203:0
How do I know which version I have?
debbie.pearce85 - crwdns2934203:0crwdne2934203:0
Hi, the system does not automatically update when I input my USB. Any ideas why?
HugoBoss1 - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 65
crwdns2936753:07crwdne2936753:0 464
crwdns2936753:030crwdne2936753:0 2,174
crwdns2942667:0crwdne2942667:0 52,878
