ComNet Ericsson Panther 600P Motherboard Replacement
  1. ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Locate the release button.: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Look for the release button on the back of the radio.
    • Press the button and pull down on the battery at the same time. The battery will come free.
  2. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the antenna counter-clockwise to unscrew it from the antenna jack.
  3. ComNet Ericsson Panther 600P Motherboard Replacement, Dials: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on the dials to remove them from the underlying pegs.
  4. ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Exterior Case: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a T15 Torx screwdriver, unscrew the two screws.
    • Using a plastic opening tool, pry the internal case from the external case.
  5. ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Front Case - Internal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, pry the case apart.
  6. ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Ribbon: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The keypad chip is attached to the motherboard by a ribbon.
    • Pull ribbon with tweezers to detach from back panel.
  7. ComNet Ericsson Panther 600P Motherboard Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Screen will be attached by a ribbon.
    • Pull screen up and away from motherboard to detach.
  8. ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Antenna, Volume, Channel Nuts: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rubber O-rings from the antenna jack, volume switch, and channel switch.
    • Once the rubber O-rings have been removed, use small needle nose pliers to unscrew the nuts on the antenna jack, volume switch, and channel switch.
    • There are washers underneath the nuts on the antenna jack, volume switch, and channel switch. Set these washers aside.
  9. ComNet Ericsson Panther 600P Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T15 Torx screwdriver, unscrew the 3.8mm screw from the case.
  10. ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ComNet Ericsson Panther 600P Motherboard Replacement, Internal Case - Back: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using any convenient hand-placement, pull the motherboard away from the case.
    • The antenna jack, volume dial, and channel dial are attached to the motherboard. Be sure to pull the motherboard downward so they clear their respective slots in the case.
    • Lift the motherboard completely free of the case.
Tim Moreau
crwdns2935283:001/13/15crwdne2935283:0
126 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-2, Carnegie Winter 2015 crwdns2935289:0Eastern Washington University, Team 1-2, Carnegie Winter 2015crwdne2935289:0
EWU-CARNEGIE-W15S1G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 420
