With a few tools, a little bit of time, and a moderate degree of commitment, you can replace a damaged display on ComNet Ericsson Panther 600P.
Look for the release button on the back of the radio.
Press the button and pull down on the battery at the same time. The battery will come free.
Twist the antenna counter-clockwise to unscrew it from the antenna jack.
Pull up on the dials to remove them from the underlying pegs.
Using a T15 Torx screwdriver, unscrew the two screws.
Using a plastic opening tool, pry the internal case from the external case.
Using the plastic opening tool, pry the case apart.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Pull ribbon with tweezers to detach from back panel.
Pull screen up and away from motherboard to detach.
