Use a spudger to remove the four rubber screw covers from the four back corners of the tablet.
Place the PH00 screwdriver and use it to remove the four 0.5 cm screws from each corner of the tablet.
Place a metal spudger tool in between the front and back panels of the tablet and begin to pry the base from the front panel by moving the metal tool around the perimeter of the tablet.
Using the PH00 screwdriver unscrew and rotate the plastic tabs that are holding the screen in place.
Before removing the screen from the cover, dissconnect the large gold ribbon cable by gently sliding the black tab out until it clicks.
Gently pull the ribbon cable from the port.
Is the flex cable detachable from the LCD
maynell Rodrigues - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Do u have the display flex cable
how much does it cost for screen
jnapps mu - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
