crwdns2935267:0crwdne2935267:0Tweezers$4.99
Press the eject button to view the laser inside.
Using the blue plastic tool and the tweezers, remove the ribbon cable.
Remove the six 1cm screws on the bottom of the device with the Phillips #1 screwdriver.
Pry the top of the device open from the right side where the buttons are located.
Pinch the plastic adapter with two fingers to remove the wires circled in red from the circuit board.
Remove the two 6.35mm screws circled in black with a #1 Philips head screwdriver.
Remove one 4mm screw circled in red with a #1 Philips head screwdriver.
The location of the springs are circled.
Using two plastic tool removers, lift the two rails up at an angle. Keep the rods angled as shown.
Lift the laser assembly out of the fixture.
Remove the rails from the disk reader.
Once the top rail is removed, the white gear will come off and under it will be one of the springs.
