This guide will walk you through removing the buttonboard. Removing the buttonboard will give you access to the buttons and the display screen.
Remove the four 9.5 mm Phillips #0 screws from the back of the device.
Pull the black plastic back case off of the device.
Lift up the motherboard and lay it flat next to the device.
Remove the four 4.8 mm Phillips #00 screws from the buttonboard.
Lift buttonboard to expose silver button plate.
