This guide will teach you how to remove and replace the buttons on your Cobra MR HH350 FLT Radio.
Remove the 11mm screw at the bottom of the radio with a #4 flathead screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the 6 rubber stoppers using tweezers to reveal screws.
Remove the 6 10mm screws that were behind the rubber stoppers with a #0 Phillips screwdriver.
Remove the cover to expose the motherboard.
Pull off the power nob at the top of the radio.
Remove the 2 6mm screws on the motherboard with a #0 Phillips screwdriver.
Hi, what is in this two holes on the metal cases? Is it some king of tune? Or switch?
Remove the screw at the bottom of the radio.
Remove the screws that were behind the rubber stoppers.
Remove the 2 screws on the motherboard.
Remove the plastic piece and the rubber button assembly.
Help! i broke the power knob off and need a replacement. where do i find these?
