This guide will teach you how to remove and replace the buttons on your Cobra MR HH350 FLT Radio.
Remove the 11mm screw at the bottom of the radio with a #4 flathead screwdriver.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the 6 rubber stoppers using tweezers to reveal screws.
Remove the 6 10mm screws that were behind the rubber stoppers with a #0 Phillips screwdriver.
Remove the cover to expose the motherboard.
Pull off the power nob at the top of the radio.
Remove the 2 6mm screws on the motherboard with a #0 Phillips screwdriver.
Remove the screw at the bottom of the radio.
Remove the screws that were behind the rubber stoppers.
Remove the 2 screws on the motherboard.
Remove the plastic piece and the rubber button assembly.
Help! i broke the power knob off and need a replacement. where do i find these?
