Cobra 29 LTD Classic Internal Speaker Replacement
  1. Cobra 29 LTD Classic Internal Speaker Replacement, Power Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement, Power Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the power switch, the leftmost knob, counterclockwise to off.
  2. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the device around and firmly pull the power cable plug to remove it from the radio.
    What is the part number of the connector? What is the part number of the correct fused power cord?
    continental59 - crwdns2934203:0crwdne2934203:0
  3. Cobra 29 LTD Classic Internal Speaker Replacement, Antenna Cable: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement, Antenna Cable: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the securing cap counterclockwise from the antenna connector.
  4. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the antenna cable to remove it from the back of the radio.
  5. Cobra 29 LTD Classic Internal Speaker Replacement, Microphone: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement, Microphone: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
    My microphone will not recieve or get out
    Keith Laws - crwdns2934203:0crwdne2934203:0
  6. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unplug the microphone plug.
    what is the wiring on a 4 pin cobra mic .
    Tony Spainhour - crwdns2934203:0crwdne2934203:0
  7. Cobra 29 LTD Classic Internal Speaker Replacement, Outer Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement, Outer Cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
  8. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently life and remove the top cover.
  9. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently set down on a hard, flat, non-conductive surface to minimize risk of shock or breaking your radio.
    • Carefully flip the radio over.
  10. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
  11. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Watch out for the wires connected to the speaker. These short wires will not allow you to move the cover very far.
    • Gently lift and remove the case cover.
  12. Cobra 29 LTD Classic Internal Speaker Replacement, Internal Speaker: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement, Internal Speaker: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement, Internal Speaker: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • De-solder the red wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
    • During reassembly you will need to resolder the components back together.
  13. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The wire may still be hot, so let it sit for 30 seconds before continuing.
    • Remove the red wire and make sure it is out of the way.
  14. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-solder the white wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
  15. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the white wire out and set it aside.
    • The cover with the internal speaker should be completely separate from the device at this point.
  16. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently flip the cover over.
    • The main body should be set aside on a non-static and flat surface. The cover with the internal speaker should now be by itself.
  17. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 6.0 mm screws counterclockwise that surround the grate with a #1 Phillips Screwdriver.
    • When removing the four screws, the speaker may detach before you flip over the cover.
  18. Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cobra 29 LTD Classic Internal Speaker Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the cover over and remove the speaker from the cover.
    • The nuts should remain attached to the speaker by lock-tight glue, however some might fall off.
Noah Negrey
crwdns2935283:010/13/13crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-37, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 11-37, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S11G37
Where can I buy that speaker from I can't find one anywhere online
Henry Guitron - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,537
