The internal speaker is located inside the device and it is attached to the bottom cover. Perform the guide on a flat non-conductive surface to avoid electrical shock and damage to your device.
Some steps in this guide require soldering. For information on how to solder, see the soldering guide.
Turn the power switch, the leftmost knob, counterclockwise to off.
Turn the device around and firmly pull the power cable plug to remove it from the radio.
Unscrew the securing cap counterclockwise from the antenna connector.
Gently pull the antenna cable to remove it from the back of the radio.
Unscrew the cap counterclockwise on the microphone plug to disconnect the cable.
My mike will.not key
My microphone will not recieve or get out
Gently unplug the microphone plug.
what is the mic wiring ?
what is the wiring on a 4 pin cobra mic .
Unscrew the top four 6.0mm Phillips head screws counterclockwise on the left and right side of the device using a #1 Phillips head screwdriver.
Gently life and remove the top cover.
Unscrew the four 6.0mm Phillips head screws counterclockwise on the left and right side of the device that connect the remaining cover, using a #1 Phillips head screwdriver.
Gently lift and remove the case cover.
De-solder the red wire that is connected to the internal speaker, with a soldering iron and the desoldering wick.
Remove the red wire and make sure it is out of the way.
Pull the white wire out and set it aside.
Unscrew the four 6.0 mm screws counterclockwise that surround the grate with a #1 Phillips Screwdriver.
Flip the cover over and remove the speaker from the cover.
Where can I buy that speaker from I can't find one anywhere online
