The fuse is part of the power cable. It burns out under high electrical current to prevent damage to the radio. The power cable should be disconnected from the power source before starting this guide.
Turn the power switch, the leftmost knob, counterclockwise to off.
Turn the device around and firmly pull the power cable plug to remove it from the radio.
Simultaneously push the fuse container together and rotate counterclockwise.
Buenas tardes,quisiera saber cuanto AMP se usa en un fusible de radio Cobra 29 LTD Clasic,gracias antisipadas,,,,
