Clearing Jammed Printrbot Simple Metal 2014 Hot End
  1. Clearing Jammed Printrbot Simple Metal 2014 Hot End, Clearing Jammed Printrbot Simple Metal 2014 Hot End: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Big thanks to Ian Lewis of Printrbot's Support team for guiding me through fixing my Simple.
    • Your printer's hot end is comprised of two stages. The beige plastic part is a thermal break between the 200C heater cartridge and the feeding mechanism above.
    • The job of the beige part is to keep the filament cool before it reaches the heated element.
    • The part pictured is made with PEEK plastic. http://reprap.org/wiki/PEEK
    • For more term definitions, see http://reprap.org/wiki/RepRap_Options#Ex...
    • Anyway, we're here because this thing is jammed. Read on.
  2. Clearing Jammed Printrbot Simple Metal 2014 Hot End, Pull off the red Teflon "sock".: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The sock may stick to the brass nozzle. If this happens, use a utility knife to separate the nozzle from the sock.
    • The sock keeps heat even over the hot end. You'll need to put it back on when printing for good results.
    • Heat the hot end to 50 degrees Celsius.
    • Cold plastic fuses the nozzle to the hot end. This is just enough to soften the PLA plastic without being at the full operating temperature.
    • Use your ratchet and wrench as shown.
    • Do not touch the hot end. 50C = 122F.
    • Use a torch to burn off plastic on the nozzle.
    • Continue until all plastic has burned away.
    • Heat the hot end to 230 degrees.
    • Slacken the idler screw.
    • Manually push filament through the hot end. Keep a firm pressure through any resistance.
    • Once the filament comes through the hot end, pull it straight out.
    • Turn off the heater. Allow everything to cool.
    • Power off the Printrbot.
    • Replace the nozzle. Tighten to hand tight then 1/8 turn.
    • Replace the red sock.
Once the hot end is reassembled, heat to normal 200C and attempt to extrude.
Reid Burke
crwdns2935283:001/24/14crwdne2935283:0
146 crwdns2915208:0crwdne2915208:0
Looks like some pictures are missing. Any plans to get those updated?
Chris Arnesen - crwdns2934203:0crwdne2934203:0
I used a torch on my nozzle and it completely deformed it. Not every torch will work, be careful. Might be better to use a stove for this.
gustavo9 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,071
