It is important to clean the A/C filters every few months, otherwise, the accumulation of dirt on A/C filters can cause the device to function improperly and expose users to the circulation of dirty air inside homes. This guide will explain the process of cleaning the filters inside a split air conditioner unit.
The steps are shown for the Zanussi split A/C; however, the guide can also be used for other similar models. In addition, the guide can be used for replacing filters in your split A/C. Follow the instructions for detailed explanations.
Turn off the air conditioner using the remote controller.
Unplug the A/C unit from its power source.
Place your hands on the edges of the lid, and pull the lid up to open it.
Grab the filter by the small tab located at the bottom.
Pull the filter towards yourself to snap it out of the slot that holds it in place.
Pull the whole filter out of the A/C unit.
Buy filters that are specifically made for your model of the air conditioner. Otherwise, the filters might not fit into the unit or the device may not function properly.
Skip steps 5-7 and continue with step 8 after you’ve purchased your new filters.
Wash the filters under streaming water:.
Slide the filter from side to side to ensure every part of the filter is washed with the stream.
Place your filters in a bucket with one part water and one part vinegar.
Leave for one hour to soak.
Wash the filters in circular motions with a soapy sponge.
Rinse the filter thoroughly with water.
Place your filters on a towel in a dry room and let them completely dry out before proceeding to the next step.
Place the filters back inside, pushing them forward until they click and fall back into place.
To reassemble your device, close the lid of the A/C and plug it into power.
I have EL that show me on the screen when I try to open my A/C and it doesn't work anymore. How can I repair it ? Please 🙏
My AC door not closed
My split ac swing is not working / moving. How can i repair it
