If you are having trouble adjusting the headband on your Skullcandy Mix Master DJ headphones, you may need to simply clean the slider tracks to remove any obstructions. This guide will show you how to that in just four few easy steps.
Remove the Skullcandy Mix Master DJ Headphones from any casing or protective gear.
Rotate the headphones so that one of the speaker cups are facing you. Remove the four Phillips 3 mm screws along the headband cover.
Gently remove the cover from the headband.
Using a moist Q-tip or small towel, carefully wipe the inside of the headband sheath.
