High Content Rubbing Alcohol$12.99
×5
crwdns2959928:0crwdne2959928:0 ↓You will learn how to take apart the necessary parts of the controller, how to clean the inside, and how certain parts are supposed to aligned or inserted into other parts.
Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
Remove the back panel from the controller.
Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
Remove the back panel of the joystick box.
Separate the rubber pads and plastic buttons from the controller.
Using a soft cleaning material, clean the plastic buttons.
Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
Using a damp, soft cleaning material, clean the rubber button pads.
Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
Follow these steps in reverse order to reassemble your device.
