Cleaning 1985-1988 Volvo 740 Throttle Body
  1. Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First, disconnect the battery.
    • Note: Always take the negative terminal off first, then the positive terminal.
    • General Tip: After disconnecting the battery, let the car sit for about 10 minutes. This will allow any residual energy left in the system to settle and it is good practice for any job you are completing.
  2. Cleaning 1985-1988 Volvo 740 Throttle Body, Removing a Throttle Body: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the throttle body on the right side of the engine. This will be between the intake tube and the intake manifold.
  3. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Within the throttle body, locate the throttle linkage cable assembly.
  4. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the throttle linkage cable assembly clockwise (to the right).
  5. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the slackened cables and slide both off of the assembly's guide.
  6. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two hoses on the top of the throttle body. Once located, gently lift them off.
  7. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a flathead screwdriver, loosen the hose clamp attaching the intake tube to the throttle body.
  8. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the intake tube from the throttle body.
  9. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the wiring clip on the underside of the throttle body.
  10. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before gently removing the wiring clip, press down on the locking mechanism.
  11. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the throttle linkage arm. With a flat head screwdriver, open the locking clip and pry off the linkage arm.
  12. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the three (3) 13mm nuts attaching the throttle body to the intake manifold. Remove those with a 13mm crescent wrench.
  13. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
  14. Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Cover the electrical contacts with a shop towel to prevent throttle body cleaner from inadvertently spilling over.
  15. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Liberally apply throttle body cleaner to the inside of throttle body and butterfly valve.
    • Use a shop towel sprayed with cleaner to wipe off thick grime if severely dirtied.
  16. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Spray electrical cleaner on the metal contacts to blast away particles in the bracket.
    • Spray off the wiring clip that attaches to the throttle body inside the engine bay.
  17. Cleaning 1985-1988 Volvo 740 Throttle Body: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a small amount of dielectric grease to the metal contacts to prevent corrosion.
To reinstall the throttle body after cleaning follow reverse directions for prerequisite guide #2
Raymond
crwdns2935283:010/11/10crwdne2935283:0
76 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-28, Regan Fall 2010 crwdns2935289:0Cal Poly, Team 3-28, Regan Fall 2010crwdne2935289:0
CPSU-REGAN-F10S3G28
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 8,320
