Defective switches can prevent the hair dryer from working properly, so we are replacing the switches. Replacing the switches should ensure the hair dryer turns on and off, and changes to hot or cold air.
Begin with the side with switches
Remove the Phillips PH0 bit
Insert the bit into the screwdriver
Unscrew the shell screw (1) with the screwdriver
5mm Phillips flat-head screw
Flip the hair dryer over to the side without switches
Unscrew the shell screw (1) with the screw driver
Remove the bit from the screwdriver and insert the Phillips PH2 bit
Unscrew the remaining shell screws (5) with the screwdriver
15mm Phillips round-head screws
Gently pull the two sides apart
Separate each side
Verify wires are connected to each switch and are in good condition
