Circular Saw Blade Replacement
  1. Circular Saw Blade Replacement, Blade: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Circular Saw Blade Replacement, Blade: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug your circular saw or remove the battery before replacing the blade!
  2. Circular Saw Blade Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press and hold down the blade lock button to keep the blade from turning while you loosen it.
    • Loosen the arbor's hex bolt in the center of the blade using a 5mm hex key, making sure to loosen clockwise since the bolt threads are reversed.
    • Your circular saw may already come with a hex key.
  3. Circular Saw Blade Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once loosened, continue unscrewing the bolt with your fingers and remove it from the saw.
  4. Circular Saw Blade Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the arbor washer.
  5. Circular Saw Blade Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Completely retract the blade guard.
    • You can hold the blade guard in place with a clamp while you change the blade.
  6. Circular Saw Blade Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Circular Saw Blade Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Set the circular saw on its side and carefully lift up the blade to unseat it from the arbor.
    • Slowly slide out the blade.
    • Use extreme caution when handling the blade!
  7. Circular Saw Blade Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When inserting the new blade, be sure to note its rotation and install it in the correct orientation.
Craig Lloyd
crwdns2935283:002/10/16crwdne2935283:0
39,267 crwdns2915208:0crwdne2915208:0
crwdns2935297:082crwdne2935297:0
Hello!
I learned a lot of important things, but I have a Question that is this Circular Saw perfect to cut Concrete Pavers?
F6 Adhesive Tape - crwdns2934203:0crwdne2934203:0
I think you need a cutting disc in your circular saw
to cut concrete.
Toon Konings - crwdns2934203:0crwdne2934203:0
the problem is that cutting concrete with a concrete disk produces a lot of concrete dust. It will kill your machine. It is not possible to stop the dust by pouring water as you would do with a tile cutting machine.
vief - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 140
crwdns2942667:0crwdne2942667:0 9,104
