Cirago M9030 Button Module Replacement
    1. Cirago M9030 Button Module Replacement, Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
    2. Cirago M9030 Button Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
      • Remove the warranty sticker across the bottom.
    3. Cirago M9030 Button Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently take the cover apart using your hands separating the top and bottom.
      • The outer shell is expected to easily come apart.
    1. Cirago M9030 Button Module Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure that the screen of the device is facing down.
    2. Cirago M9030 Button Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
      • Raise the bottom edge of the hard drive 15 degrees up from the device.
    3. Cirago M9030 Button Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
    1. Cirago M9030 Button Module Replacement, IDE Connector: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cirago M9030 Button Module Replacement, IDE Connector: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
    2. Cirago M9030 Button Module Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
    3. Cirago M9030 Button Module Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
      • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
    4. Cirago M9030 Button Module Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
    5. Cirago M9030 Button Module Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
      • Completely remove the IDE connector from the device.
    1. Cirago M9030 Button Module Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cirago M9030 Button Module Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
      • Completely remove the motherboard.
      • The motherboard should slide out easily.
    1. Cirago M9030 Button Module Replacement, Button Module: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Set aside the front cover.
      • Flip over the motherboard.
      • Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
    2. Cirago M9030 Button Module Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the tweezers, lift up the button module to a 180 degree angle.
      • Leave the button module attached by the ribbon.
      • Flip over the motherboard with the button module still attached.
    3. Cirago M9030 Button Module Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Fold the button module over the motherboard.
      • Using the tweezers, remove the ribbon pin.
      • The ribbon pin should snap completely off of the motherboard.
    4. Cirago M9030 Button Module Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cirago M9030 Button Module Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • The ribbon should easily detach from the motherboard.
Ryan Sutardji
crwdns2935283:006/29/12crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-4, Regan SU 2012 crwdns2935289:0Cal Poly, Team 1-4, Regan SU 2012crwdne2935289:0
CPSU-REGAN-SU12S1G4
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 1,417
