A guide to show how to replace Chumby One motherboard.
Remove 4 self-adhesive plastic dots covering the screw holes.
Remove the four 2mm screws with a Phillips screwdriver.
Disconnect the battery connector from the motherboard with a plastic opening tool.
Disconnect the microphone connector from the motherboard with a plastic opening tool.
Remove the display ribbon cable from its socket with a plastic opening tool.
Remove the volume knob from the side of the Chumby One with a plastic opening tool.
Remove the four 6mm screws using a PH000 bit on the inner chassis.
Remove the inner components from the outer shell.
Remove the speaker connector using a plastic spudger.
Remove the Chumby button connector using a plastic spudger.
Remove three 6mm screws using a PH000 bit.
Remove the motherboard by pulling straight away from the housing.
