A guide to show how to replace LCD Screen in the Chumby One.
Remove 4 self-adhesive plastic dots covering the screw holes.
Remove the four 2mm screws with a Phillips screwdriver.
Disconnect the battery connector from the motherboard with a plastic opening tool.
Disconnect the microphone connector from the motherboard with a plastic opening tool.
Remove the display ribbon cable from its socket with a plastic opening tool.
Remove the volume knob from the side of the Chumby One with a plastic opening tool.
Remove the four 6mm screws using a PH000 bit on the inner chassis.
Remove the inner components from the outer shell.
Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
Remove the metal shield from the front case using a plastic opening tool.
Remove the LCD screen from the outer case using a plastic opening tool.
