Chromo Noria Motherboard Replacement
  1. Chromo Noria Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
  2. Chromo Noria Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
  3. Chromo Noria Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
  4. Chromo Noria Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
  5. Chromo Noria Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
  6. Chromo Noria Motherboard Replacement, Camera: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Noria Motherboard Replacement, Camera: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully detach one side of the black tape from the board.
  7. Chromo Noria Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Noria Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
  8. Chromo Noria Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Noria Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
  9. Chromo Noria Motherboard Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your spudger tool, remove speaker from the backboard.
  10. Chromo Noria Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Noria Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger tool, detach the speaker from the back of the screen.
  11. Chromo Noria Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Soldering Iron, desolder both wires from the motherboard.
  12. Chromo Noria Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Noria Motherboard Replacement, Motherboard: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
  13. Chromo Noria Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three pieces of tap keeping the wires in place.
  14. Chromo Noria Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromo Noria Motherboard Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a spudger on the small black pins on either side of the flex cables.
    • Gently push the spudger towards the back of flex cables to unlock the flex cable.
    • Remove the flex cables from their insert.
  15. Chromo Noria Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the eight connections.
  16. Chromo Noria Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard to remove.
Nick Rohn
crwdns2935283:010/30/16crwdne2935283:0
475 crwdns2915208:0crwdne2915208:0
Baylor, Team 5-6, Williams Fall 2016 crwdns2935289:0Baylor, Team 5-6, Williams Fall 2016crwdne2935289:0
BU-WILLIAMS-F16S5G6
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 319
