Chromo Inc. T2 Motherboard Replacement
  1. Chromo Inc. T2 Motherboard Replacement, Removing the Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Motherboard Replacement, Turn it around: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the tape holding the big flex cable in place.
    • Using your plastic opening tool, gently push back the gray connector to free the flex cables and then pull them out.
  4. Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
    • Using a pair of tweezers, gently grasp the flex cable and disconnect it from the connector.
  5. Chromo Inc. T2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws holding the motherboard.
  6. Chromo Inc. T2 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your soldering iron, desolder the six wires on the side of the logic board.
    • Note: Remember where these wires go as re-connecting them incorrectly can lead to damaging the device!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  7. Chromo Inc. T2 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromo Inc. T2 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your soldering Iron, desolder the grounding cable on the motherboard.
  8. Chromo Inc. T2 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your motherboard is now ready for replacement!
Ismael DeLuna
crwdns2935283:001/21/15crwdne2935283:0
637 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-1, Watkins Winter 2015 crwdns2935289:0USF Tampa, Team 15-1, Watkins Winter 2015crwdne2935289:0
USFT-WATKINS-W15S15G1
crwdns2942667:0crwdne2942667:0 689
