Chromebook x360 14-da0011dx Fan Replacement
  1. Chromebook x360 14-da0011dx Fan Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Fan Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook x360 14-da0011dx Fan Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook x360 14-da0011dx Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
Jake Williamson
crwdns2935283:002/14/23crwdne2935283:0
559 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-2, Virtue Spring 2023 crwdns2935289:0Western Carolina University, Team 1-2, Virtue Spring 2023crwdne2935289:0
WCU-VIRTUE-S23S1G2
crwdns2942667:0crwdne2942667:0 341
