Chromebook Pixel (2013) Battery Replacement
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook Pixel (2013) Battery Replacement, Pop it open: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
    Do I have to flash the bios when replacing the battery?
    Clive Gorman - crwdns2934203:0crwdne2934203:0
    There is no need to flash the BIOS if all you want to do is replace the battery.
    Kevin Fessler -
    I want to install windows on to the chrome book pixel 2013 but i have concerns regarding the touch screen. Can you help? Is there any video that you have uploaded for the installation?
    Hari Krishna Bharadw Pudipeddi - crwdns2934203:0crwdne2934203:0
    How to check if screw is already removed or not? By not opening its back.
    Abdullah Ishfaq - crwdns2934203:0crwdne2934203:0
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook Pixel (2013) Battery Replacement, Unplug the battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Chromebook Pixel (2013) Battery Replacement, Install the new battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
crwdns2935229:09crwdne2935229:0
Kevin Fessler
crwdns2935283:004/16/16crwdne2935283:0
1,830 crwdns2915208:0crwdne2915208:0
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - crwdns2934203:0crwdne2934203:0
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 7,561
