Chromebook Flip C302 Back Cover Removal
  1. Chromebook Flip C302 Back Cover Removal, Chromebook Flip C302 Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Chromebook upside down. You may want to place paper or another soft material between the lid and your work surface, so as not to scratch it.
    • Remove the 10 (6.14 mm) case screws with a T4 Torx driver.
  2. Chromebook Flip C302 Back Cover Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger (or prying tool, or fingernail), gently lift the feet at the rear of the laptop (near the hinges). Get underneath the pad, then release the adhesive by sweeping in a circular motion.
    • Store the feet upside down and not sticking to anything―you can likely re-adhere them after replacing the cover.
  3. Chromebook Flip C302 Back Cover Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #00 screwdriver to remove the 3.17 mm screws from beneath the rear feet.
  4. Chromebook Flip C302 Back Cover Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic prying tool (avoid metal, as the case is easily scratched), lift the back cover from the case. The underside of a hinge is a good place to start.
    • You'll feel the cover give way, but there are loose clips holding the lid on. Work gently around the lid, prying and moving beyond clips when you encounter them.
  5. Chromebook Flip C302 Back Cover Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull away the back cover. You now have access to the battery, the write-protect screw, and other components.
Kevin Purdy
crwdns2935283:004/11/19crwdne2935283:0
4.373 crwdns2915208:0crwdne2915208:0
Might wonder - how can I track a cell phone by number alone?
You can not only find out the location of the tracked person, but also track the history of all the places where he was. You no longer need to contact your mobile carrier to track someone. Instead, you can track the location of a mobile phone by its number with a mobile phone tracker app - rastrear celular por número
Find Car - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,995
