Chromebook Flip C302 Back Cover Removal
  1. Chromebook Flip C302 Back Cover Removal, Chromebook Flip C302 Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the Chromebook upside down. You may want to place paper or another soft material between the lid and your work surface, so as not to scratch it.
    • Remove the 10 (6.14 mm) case screws with a T4 Torx driver.
    On my machine, an Asus C302C Chromebook, a T4 Torx driver was required. A T5 Torx driver was too large.
    Paul - crwdns2934203:0crwdne2934203:0
    I concur - T5 too big
    Kevin Pierce -
    With mine, the T4 supplied with the battery was too small. I was able to use a T5.
    rob wilson - crwdns2934203:0crwdne2934203:0
    Noted! I’ve updated the guide.
    Kevin Purdy - crwdns2934203:0crwdne2934203:0
    My screws just spin I will not come out
    granyjane - crwdns2934203:0crwdne2934203:0
    T5 Torx was the one that worked for me. T4 was too small. ASUS Chromebook C302C. Screws came out fine with a T4, but I couldn’t get them back in until I realized that the T5 fit better and was able to get the screws back in.
    Wayne Lunsford - crwdns2934203:0crwdne2934203:0
    On ours a T5 was needed. Maybe some machines were built with T4s and some with T5s.
    MaggieL - crwdns2934203:0crwdne2934203:0
  2. Chromebook Flip C302 Back Cover Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger (or prying tool, or fingernail), gently lift the feet at the rear of the laptop (near the hinges). Get underneath the pad, then release the adhesive by sweeping in a circular motion.
    • Store the feet upside down and not sticking to anything―you can likely re-adhere them after replacing the cover.
    Do NOT try to remove the other (front) two feet! They attach differently and are not designed to be removed. There are no screws hidden below them.
    KEVIN PRICE - crwdns2934203:0crwdne2934203:0
    Wish I’d read this comment before I tried prying one of the two front feet off. I didn’t break it, but now it won’t go completely back in place. This is in the original instruction above, but I wasn’t reading carefully…
    Wayne Lunsford -
  3. Chromebook Flip C302 Back Cover Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #00 screwdriver to remove the 3.17 mm screws from beneath the rear feet.
  4. Chromebook Flip C302 Back Cover Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic prying tool (avoid metal, as the case is easily scratched), lift the back cover from the case. The underside of a hinge is a good place to start.
    • You'll feel the cover give way, but there are loose clips holding the lid on. Work gently around the lid, prying and moving beyond clips when you encounter them.
  5. Chromebook Flip C302 Back Cover Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull away the back cover. You now have access to the battery, the write-protect screw, and other components.
Kevin Purdy
crwdns2935283:004/11/19crwdne2935283:0
4,373 crwdns2915208:0crwdne2915208:0
Might wonder - how can I track a cell phone by number alone?
You can not only find out the location of the tracked person, but also track the history of all the places where he was. You no longer need to contact your mobile carrier to track someone. Instead, you can track the location of a mobile phone by its number with a mobile phone tracker app - rastrear celular por número
Find Car - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 5,997
